Summary
This is the space where I will post updates regarding the development of Ribbons. This will include: firmware updates and changes/bug fixes I’m working on.
Only admins (myself) can post on this topic. I will update the post below this one to share what I’m currently working on / what I’m aware of and then add new posts when firmware updates are available.
Future Updates Being Considered
When Ribbons is released, all of its core features will be implemented and it will do exactly what the manual says it will do. I may occasionally investigate and implement additional feature requests.
Potential To-Do’s / Feature Requests Being Considered (last updated Feb 2026):
- Investigate new noise flavors for NOISE knob
- Investigate option for Disintegration Loop and 4-track looper Touch footswitch behavior to be record > overdub > playback instead of record > playback > overdub
- Investigate MIDI clock sync of Disintegration Loop touch mode
- Investigate new MIDI CC option for the 4-track looper to run post-effects
- Investigate new MIDI CC option for 4-track looper pan per loop
- Investigate MIDI transport controls for 4-track looper
- Investigate stereo spread / mono for Crinkle / dropouts control via MIDI
- Add velocity support for sine wave synth
Misc. UI improvements and bug fixes:
Firmware Releases:
Click Here for Older Versions
- 4/19/2023, v1.3: New touch modes (Crushed Cassette and Disintegration Loop), Tape Saturation, UI Improvements, Sine Wave Synth Improvements, Repeater Improvements
- Change list:
- New Touch Mode: Disintegration Loop - A looper with controls for decay and speed/direction. This may be one of the few loopers out there that is capable of through-zero speed control without artifacts while recording to a loop. This mode can be used as a tape delay or a >20 second looper.
- New Touch Mode: Crushed Cassette - Sample rate reducer and bit crusher with mu-law companding.
- Tape Saturation can now be enabled by sending Ribbons a MIDI CC52 >0. This is global and persistent between power cycles.
- Sine wave synth now has controls for attack, release, and volume via MIDI CC.
- Stepped parameters now have stepped LEDs for improved visual feedback.
- Improved UI feedback when loading presets: once loaded, each preset has a unique glow pattern.
- Slight improvement to the way the Repeater touch mode triggers the playback of samples.
- v1.3.1 file adds a small amount of gain compensation when saturation is enabled so there is no noticeable boost or cut when engaging/disengaging the pedal. It also resolved a slight issue with the dropouts when in mono in / mono out mode.
- Download files:
- Download this version if your unit was manufactured in 2022 and glows green/blue when you enter bootloader mode:
- Download this version if your unit was manufactured in 2023 and glows purple/blue when you enter bootloader mode:
- If you don’t have access to a MIDI controller and would like enable saturation on your Ribbons by default, we’ve created an extra firmware update file for you. You will need to run a factory reset after completing the update to enable saturation.
- Download this version if your unit was manufactured in 2022 and glows green/blue when you enter bootloader mode AND you want saturation enabled by default instead of compression:
- Download this version if your unit was manufactured in 2023 and glows purple/blue when you enter bootloader mode AND you want saturation enabled by default instead of compression:
January 2025 — The change list below reflects firmware version 2.0. If you would like to upgrade but are unsure when your unit is from, please review this post first.
- Units manufactured in 2024 ship with firmware 2.0 already installed — no need to update.
- Units manufactured in 2022 require a hardware upgrade to run 2.0. Please email support@kinotoneaudio.com to coordinate.
- Units manufactured in 2023 can update to firmware 2.0 by installing these files. Instructions for updating are documented in our online manual here.
IMPORTANT! PLEASE NOTE: To update your 2023 unit to firmware 2.0, you must complete two (2) updates in a row. Your current presets will be erased and replaced with new ones.
STEP 1, BOOTLOADER UPDATE — Install the bootloader file first using Ribbons2023Bootloader2.0.wav. When the file is finished playing back, wait for all 6 LEDs to light up green. If you see 6 green LEDs (not two, not four - all 6!) then you are good to proceed.
STEP 2, RE-ENTER BOOTLOADER MODE — Remove power from Ribbons. Then, re-enter bootloader mode.
STEP 3, FIRMWARE UPDATE — Now you can install firmware 2.0 using Ribbons2023Application2.0.wav. After updating, your Ribbons will boot up normally.
Firmware 2.0 Change List:
Touch Mode enhancements, audio enhancements, new utilities
New UnrealPlayer Touch Mode — Emulates the imperfections of lossy digital codecs and early streaming services. Provides controls for spectral degradation (T1) and spectral blur (T2).
4-Track Looper + Touch Modes — You can now use the 4-track looper and any of the Touch Modes simultaneously.
Magnetic Dance enhancements
- 20 second loops — Magnetic Dance has been upgraded from a 1 second micro-looper to a macro looper that allows up to 20 second loops.
- Double buffering — You can record a new loop while the current loop plays back. The old loop fades out while the new one fades in.
New utilities — 3 handy utilities can be configured on the pedal and saved into a preset:
- filter resonance
- +/- 6 dB boost or cut
- Compression or Saturation (easily switch between them)
New presets — New factory presets showcase a wider variety of “lo-fi mediums.”
Expanded presets — There are now 32 preset slots available. Presets 1-8 can be accessed directly on the pedal, while the full range can be accessed via program change messages.
Reverb revamp — The reverb effect has been enhanced for a smoother sound at short decay times and better dry/wet mix. Same lush sound at long decay times.
Mix control revamp — Added all-pass compensation and equal power curve to the mix control for overall improvement.
UI and other improvements
Fine-tuned UI — Redesigned all user interface code for smoother and faster operation.
Page navigation — One tap of the push button will show your current page, and multiple taps advance the page. This uses an 8 second timer. The idea is to show the current page as a reminder if you haven’t touched the pedal in awhile, but to not interrupt flow if you are actively editing settings.
Clipping meter — Added a clipping meter for input level monitoring. The Bypass LED changes color if your input audio is too hot.
Persistent bypass state — The bypass state is now persistent between power cycles and state saving occurs more frequently.
Quieter bypassing — Crossfading has been improved for quieter bypassing when using the buffered bypass option.
Hands-free looping — You can toggle through the 4 tracks and clear loops hands-free using the footswitches.
Enhanced looper visual feedback — The Bypass LED flashes when switching between normal operation and looper mode, regardless of the pedal’s bypass state. 4-track looper color is more distinct when recording to avoid confusion between recording and playback colors.
Preset LED feedback — After loading a preset, the LEDs briefly glow to indicate the preset color and then return back to normal UI.
INIT preset protection — The INIT preset can no longer be erased, and the pedal provides a warning if you attempt to do so.
MIDI CC improvement — MIDI CCs have been reallocated to improve compatibility with all MIDI controllers. The MIDI clock ignore setting is also now persistent between power cycles.
Bug Fixes
- Fixed issue with Disintegration Loop length calculation when max loop length is exceeded.
- Resolved a subtle whistle sound that occurred when using Tape Stop or Broken Machine with the Noise parameter turned all the way up.
- Addressed issue where MIDI CCs and presets loaded to 99.6% instead of 100%.
- Fixed LED bug after mapping parameters to CV/EXP.
- Fixed LED bug when loading presets and the Repeater Touch Mode is selected.
- When a program change is sent, the preset UI hovers over the last preset loaded via PC message.
- Corrected the factory reset process to prevent accidental entry into bootloader mode.
