Microtonal Ghosts
I’m boldly creating a thread for anyone making music with the synths of Kinotone pedals, particularly Ghosts, but not exclusively.
As a sort of PSA, if you have a Ghosts and a midi keyboard, you absolutely should experiment with the “user” scales and making your own for using it as a synth. I finally bought a Keystep 37 and figured out how to load the user scales.
I’d been getting deep into just intonation, and I find microtonality to be one of Ghosts’ superpowers. Are there any other hardware physical modeling synths that allow for customizable microtone scales? Probably something like Iridium, but not in a guitar-pedal-sized object that isn’t $1000+.
I absolutely hope for key velocity in the next firmware and would love expanded control of the air mode for longer attack times, and other harebrained wishes, but, as is, y’all need to mess with this mode.
Try out the hyperconcord scale: it’s gonna blow your mind. I’m not a keyboard player, but a beautiful scale hides my ignorance. Regardless, please, all you Ghosts users, don’t let this mode go unexplored.
One last tip for synth playing: turn the tone all the way down, or start with tone very low. It makes for a very tasty sine wave generator and the tone can be brought up for emphasis.
That’s brilliant! As I reading this, a thought occurred to me. It would be really cool to tune s synth to Just or Meantone Temperament and if you want to play a song in a different key, set the key and the synth will retune for the temperament in that key.
And if you a wolf tone, it can adjust the frequency in real time to minimize the the Pythagorean Coma. That does mean that one, maybe both of the keys in the wolf tone will play two different notes depending on other notes in the melody or harmony. That might be too much. Might be better to still avoid wolf tone.
I just got a Ghosts.
I was (perhaps naively) thinking that I could load a microtonal scale and then the CHORD and ROOT knobs would adhere to that scale, and that anything I run through the pedal I would be able to apply the resonator at those microtonal frequencies. But it looks like it just lets you play the pedal as if it was a synth, albeit a microtuned one.
I mean I already have a microtuning capable synth (Korg Monologue) so it’s not massively appealing like this.
You can easily define your own custom resonator chords using MIDI and “apply the resonator at those microtonal frequencies” exactly as you suggested. You just have to set the chord to USER and set the EXCITER TYPE to “vocoder hold”.
You can read all about it in the manual.
Using the CHORD knob to set different chord structures in a microtuned system wouldn’t make any sense. In many microtonal systems, terms like major 9, minor 11, perfect fifth, etc have no meaning.
There are ways that I almost wish that CHORD and POSITION knobs interacted with the midi keyboard too. For instance, I love to use the octave CHORD position with the contact mic to do single note lead lines, but the ROOT knob is too fiddly to find the right note without hitting an accidental or two in the process. Thus, I think a sort of monophonic octave mode would be cool where you can determine the root with a midi keyboard.
But, yea, it doesn’t make sense from the hardware perspective to have those knobs function the same way for custom scales.
Can’t have your neutral thirds and eat them too.
If you use vocoder hold on the Hyperconcord or 7-limit JI scales and mash random inversions, I think you’ll find interesting chords for the resonator.
Quick question for Jaak: what is the hypercondord scale? Seems like there are two micro intervals but otherwise a pretty normal sounding scale.
Your interest in this has made me realize there was a small mistake in our online manual. The scale names used in the 2nd and 3rd presets were switched. So the scale you are enjoying is actually the 29th harmonic rainbow. I just updated this.
Here is some more info about the user scale / chord presets:
1. Init
  • Tuning: Equal temperament
  • Chord: Herbie Hancock minor 9 voicing
2. Dark shifter
3. String Loops
4. Glitter Physics
  • Tuning: 7 limit JI
  • Chord: Not sure what to call this chord - discovered it by ear
  • Scale workshop screenshot:
5. Harmonic Pulse
  • Tuning: 13 EDO Subset - inspired by an Aphex Twin microtonal scale
6. Sparkle Shifter
  • Tuning: 666 EDO Subset - inspired by an Aphex Twin microtonal scale
Yeah, I agree there’s some really exciting potential in deeper MIDI interaction between CHORD, ROOT, and VOICING, but it comes with a few tricky edge cases. We talked about some of this here.
For example, if we made ROOT do transposition and VOICING do inversion on incoming MIDI notes, a beginner could plug in a keyboard and immediately get “wrong” notes (everything shifted or inverted) without understanding why. Also, ROOT is currently as a quick way to switch between “MIDI Note Takeover” and normal front panel control, so repurposing it would mean we’d need a new way to handle that mode switch.
I’m with you on that. A monophonic chord mode where the keyboard sets the root would be useful. I’ll add it to our list of things to consider for a future firmware update.
Awesome, thank you! I’d been looking into Amelia Huff’s work but couldn’t square the scale of preset 3 with the short video she made about it. But this makes sense!
Thanks also for your thoughts about the monophonic mode: I think it would be cool. I’ve been listening to the karplus strong sounds of Kali Malone’s new album Magnetism and want to achieve some of the boldness of really big karplus plucks. The octave mode and its subtle detuning gets pretty rich.
Does anyone have any recommendations for Ipad apps to use with microtonal scales for connection with Ghosts? I tried Synth One (using Colundi scale) but I couldn’t get it to work. I’m not even sure it’s outputting MIDI as all the MIDI options seem to be about input.
I’m not familiar with Synth One but you can create Colundi scales in Scale Workshop and then export the MTS Sysex Bulk Tuning Dump file that Ghosts expects. Then send this to Ghosts using Sysex Librarian or Midi-OX.
I’m quickly outgrowing my Keystep 37 for microtonal scales and am eyeing the isomorphic Intuitive Instruments Exquis to map custom subset scales in 31 EDO.
The Exquis has MPE capability, so you can vary the pitch or timbre of notes by pressing the keys in the x and y axes. Ghosts doesn’t work with MPE, right? If that’s the case, would this kind of wiggling on one key of the Exquis affect all notes? It would still be cool if, say, tone and position were mapped to these axes of the Exquis.
Is anyone else using an isomorphic keyboard (or other controller) for microtonal stuff?
Thanks and hope this makes sense!
There’s a treasure trove of women artists who work in microtonal. I’ve placed some bandcamp pages here:
That last message was faithfully saved on this thread as a draft for quite some time! And making a mess of things editing on my phone
Regarding microtonal, I have hundreds of go-to scales readily applied on Push 3 standalone
The Exquis is such a beautiful way to play. I’ll try to bridge what I think you could expect, at least from push, and you would still want to confirm and peer-review this:
Push puts its tuned drum scales into multichannel pitch bend. This also follows global scale/key.
And I believe melodic instrument layout is still translated from pitch bend, but single channel. Actually, this is no longer the case. It’s true micro tonal, both the live session and the push. It’s instrument dependent, because not all instruments are MPE enabled, but all Ableton instruments can accept pitch bend. I believe it’s scaled to 48±
This poses a decision, as the real estate only lights up differently on the pads: do you want to takeover the layout to highlight the tonic on microtonal scales, or do you just want to play varying micro intervals in chromatic tuning? To be clear, I’m not talking about niche scales and note quantizing. I’m talking about scala derived tunings. By default, center pitch is dictated by your finger placement and then relative throw there. And you can change it to relative to pad, rather than relative to finger. Much like a fretless instrument, you can change in settings whether pitch is relative to the pad, in which case your playing will determine the pitch. But in the second example, you’ve still tuned your instrument conventionally, by P4ths, say.
Typically if the number value is less than 12-EDO I’ll opt for the scales true layout. But the grid gets somewhat ill-allocated with larger theoretical scales. Not a delemna on the exquis
So a reframing of the question might be whether ghosts can pitch bend when it is key tracking? Then You’d have to double check how exquis is implemented; I forget off hand
Oh crap, now I get it: the additional intervals on ghosts do they shift? Well, I’d gather from all that, only in user scale position. if ghosts can accept other scales than could it not create further intervalic relations with said scales? I don’t believe that’s how it works. and could you shift the ghosts in unison? Or say play sparks synth micro tonally ? Again, as a monosynth, perhaps
Kali Malone is what I’m listening to about 50% of the time, lol. Thanks for some of these others! I’ll respond to your other, highly detailed message in a bit.
Thanks again for this generous response. I’ll be honest that some of your questions are over my head but, generally, as long as I can create my own tunings, I’m not too worried about the ability to bend the frequency further. Right now, I’m using a subset of 31 EDO on my Keystep 37 that is basically a diatonic scale with some septimal and undecimal intervals on the black keys for flavor.
Because you’re familiar with Exquis, I’ll stick with that for questions. MPE is somewhat extra for me: it seems cool, but I’m more interested in whether Exquis is a good controller to learn to play isomorphic controllers. And if MPE is an option, I’d likely be more interested in altering timbre rather than pitch with the x and y axis of the Exquis keys.
I’m most interested in playing a subset of 31 edo with, say, 18 notes/octave.
You might get a kick out the Partch 43 layout I made for the now-defunct sensel morph…
Another one
Hi @Jaakjensen , you’re right: in microtonal systems/context, it wouldn’t make any sense to use the same terminology that we find written on the chord-section of the pedal (tonal chords like Maj9 etc.), but I think that it’s really a pity - and quite limiting - not to have the possibility of moving across different microtonal chords in a smooth way (= turning a knob). if I got it right, the only way now is switching between different presets, where one user chord/scale is saved on each preset, right?). Also, even if it wouldn’t correspond to what’s written, it would be totally awesome to set a microtonal tuning system, and then being able to easily change inversions & voicing through a simple knob, even if it doesn’t correspond to the text. I know that this would be kind of expert-user nerdy stuff and not friendly for everybody, but in my opinion that feature would expand massively ghosts microtonal possibilities.
Also, last question as an ableton user: do you plan to expand the “microtonal language” ghosts speak? for example, reading .scl scala files? It would be insanely great to have all the tuning flexibility that ableton implemented since Live12, received correctly by Ghosts. Is there a possibility in the future?
Thank you very much for this awesome pedal,
best, Zeno
No, you can set the pedal to MIDI vocoder mode and send MIDI note data and play any microtonal chord you want, sequence them, etc.
We do not. It only requires a small amount of effort to drop a scala file into scale workshop and generate the MTS bulk tuning file that Ghosts requires.
Thank you @jaakjensen !
