Toggle tape effects while loops keep playing
I’d like to be able to toggle tape effects on/off while my loops keep playing. I thought mapping an expression pedal to the mix know might do this but turning the mix down also lowers the volume of the loop.
Is there a way to do this?
You can do this with presets! While your loops are playing back, load up INIT. Basically works as an “off” switch - your loops continue to play back but your signal becomes transparent.
Use a custom preset that you like as the “on” switch and you can edit the tape effects from there.
Preset are great for rapid / dramatic transitions.
Awesome, thanks. I’ll give that a go.
