Hi @MrKiammidk and thanks for chiming in @TheTimberOwls ! That info is all right.
As they mentioned above, the particular keyboard you have is not directly compatible with our pedals as they don’t use USB.
The easiest / most common setup is to use a keyboard with a DIN MIDI output.
Once you have one you can check out this thread for some verified cable solutions that adapt DIN MIDI to TRS. It works the same way for Ribbons and Sparks.
If you have a Type A keyboard and cables it should be plug and play. If you need to switch types you can reposition the jumpers on Sparks. It’s very easy and there is a section about this in the online manual.
Hope that helps. Let me know if you have other questions. ![]()
