Hey Jaak, I’ve been having a blast with repeater, the tap tempo works seamlessly.
I was wondering if the T2 control is supposed to control volume? In the manual it just says mix input, I’m using standard usually, but wondering if it’s possible to lower the volume of the repeat? It’s loud in the mix, it definitely doesn’t seem to change the volume if I hold the repeat and adjust the knob, also doesn’t seem to affect volume when I adjust in between sampling a repeat,
It does however work when set in 100% loop no dry as stated.
Cheers
