Is possible to the Hands-free track selection remember the state when you switch to tape effects and return to 4 track mode?
I mean, I set bypass switch to hands-free track selection, but if I go to change some tape effects parameters when I return to 4-track mode the bypass switch is the normal bypass mode.
If you’re switching back to the tape effects, you must be using your hands and aren’t “hands free” anymore. So Ribbons assumes you’re interacting with the pedal using your hands and that you don’t need to be in that mode anymore.
I understand that there is an extra step involved if you’re jumping back and forth but I think it’s good for Ribbons to quietly turn this off in the background when it isn’t being used - I feel like it can help prevent confusion for beginners, especially if it’s accidentally turned on.
