Feature request: expression pedal mappings saved with presets?
being able to have different expression pedal settings/mappings for different presets would open up so much for me! would that be a feature that’s possible to add? I’m imagining whatever parameter(s) you have EXP mapped to when you save, it would store and then recall (replacing whatever mapping its currently set to) when you load the preset
thanks so much!
I have a ribbons from the first batch and I’m so grateful for how much this amazing pedal has evolved over its life.
blessings and gratitude
I think it’s an interesting request but it would waste a lot of flash memory. There are 32 presets (8 on board and 24 available via MIDI PC) and each would need 32 bytes to recall all the settings that can be mapped. That’s a total of 1kbyte of flash memory. That may not seem like much from the perspective of a computer but it is a lot for the microcontroller we use inside Ribbons.
I would consider investigating a MIDI controller if you need more advanced on-demand mapping and external control of Ribbons.
