Feature Request - Dry Kill (variation)
I know the mix can be set to 100% wet, but I was looking for something a little different.
This might be unique to my setup, but I typically run ribbons in a parallel loop, and sometimes I only want to hear the wet output of the touch & loops. I.e., the dry signal only feeds the input of the touch and loops, and doesn’t also go directly through the effects to the output.
It’d be kind of like having a more typical delay/looper/reverb in dry kill mode.
Is this possible and is it something others might use?
Hey thanks for the feature request. This is a cool idea but probably not something we’d consider implementing. We’d have to add in a dry kill control to every DSP block in our codebase to accommodate it and I’m just not sure it would be worth the effort.
