Feature request: 4 track looper pre/post fx
It’s fun to create soupy loops in the looper, Magnetic Dance and/or Disintegration Loop. Then it’s fun to play over those. It would be nice if we didn’t have to apply the same set of tape effects (wow, flutter, etc) to everything. What if you could dial up an extra wow-y hi-cut tone to lay down a drone, then a lo-cut tone with dropouts for a melodic motif, and while all that loops, solo over it with flutter and reverb?
If we had a toggle to print effect in the looper(s), we could record each track, or even each pass, with a different effect stack and then play over it with different or even no Ribbons effects in the mix.
My probable workaround will be some kind of parallel mixer so I can bypass Ribbons once I have my loop looping, but the ability to print effects rather than have them apply globally would be spectacular.
I love Ribbons. Thanks for making it. It’s really pretty amazing.
I was literally going to ask about this today: there’s no way to “bounce” into a loop right now which would be useful. Ribbons is already a very complicated pedal so I understand why it might seem overwhelming from a user experience perspective to have that capability (and I don’t know off the top of my head what the interaction should be if you were to do it). But essentially as of 2.0 Ribbons is a tape studio in a pedal, the only thing I can’t figure out is how to ping pong a la https://www.youtube.com/watch?v=cZanByojSCI
(Disintegration Loop is essentially exactly what I am talking about: I want loops on the looper to be able to do what Disintegration Loop does.)
Seems unlikely. What would be an easier compromise would be to make a midi cc to have the 4-track looper run post-effects. This has been discussed and Jaak sounded down to implement it if there was enough interest. Post-effect looping would be huge for me and would allow for this “imprinting” a la Blooper, but not for the effects to accumulate after each pass.
Making every one of the 4-track tracks into the disintegration loop seems cumbersome. If every loop is running into the same effects to degrade it, then there is little difference between what you are suggesting and running the disintegration looper after the mix of the 4 looping tracks. The only way that would be possible would be to use the direction knob as a kind of “erase-head” mod, which would allow not only overdubbing but adjustable decay. This seems like a lot of leg work and a reworking of stuff that is integral to the pedal’s architecture. It would be cool, but just use the Disintegration Loop touch mode?
So, yeah, just creating the option to have the loop run post-fx is the way to go. This is the trouble with viewing Ribbons as an infinitely revisable sandbox. It tempts one to make it a cure-all, but the moment it can do everything, it defeats the point of it being a finite pedal with quirks that affect one’s playing in unexpected ways.
Yes - looper post effects is what I’m thinking.
Don’t get me wrong, I think Ribbons is fantastic just as it is. I’m lucky enough to have gotten a new one with the 2.0 software already on board.
I just found myself creating some awesome soupy degraded loops and wanting to play a cleaner guitar on top of them. I’ve been thinking about options like a parallel mixer, but figured it couldn’t hurt to mention this idea here. I think the Mood 2 spoiled me a bit for this - the ability to apply the wet side to just the input, just the micro looper or to both.
Looper post effects would be great!!
Today I’ve been playing with magnetic dance a lot, made some awesome beds, organic and full of flow. Now would be fantastic to record to one track of the 4-tracks looper and made another one (or three!) on top.
+1 for recording the looper post fx as an option.
This pedal has so much and in just a few days I’ve already had a ton of fun with it.
Being able to record different fx settings to the loops or maybe one setting per track would make this next-level amazing.
I’ve added this to the list of things to investigate for firmware v2.1. I can’t guarantee it yet but if we implement and test it and don’t find any major issues, we’ll add it.
Thanks for the request!
Let me add my request regarding the 4-track looper.
Ribbons has packed an incredible number of features into such a small enclosure, and I’m constantly amazed at how it continues to evolve day by day.
I’ve tried countless loopers over the years, and the looper functionality in Ribbons is undoubtedly my favorite.
With the discussion in this thread about pre/post settings, I’d like to add one more request.
If pre/post settings and recursive processing become possible, I believe adding a Decay setting would make it the perfect looper.
I’d love to see a Decay setting that allows the volume of looping sounds to gradually fade with each recording.
This feature would enable loops that continue to evolve over time, with effects recursively applied.
I hope you’ll consider this suggestion!
The Disintegration Loop touch mode already does this, so I don’t think we’ll be adding it to the 4 track looper.
Can I ask if there has been any investigation happening yet? The possibility of recording post fx and then adding more on top of it with different settings is just wild, for a pedal that is already full of exciting features :slight_smile:
We just dropped a big update with 2.0 and I’m mainly focusing on new product development at the moment. Post-fx looping is on the list though and probably wouldn’t be too hard to implement as an option you can configure via MIDI cc. We generally work on firmware in sprints and there will probably be another one later in the year.
Was fortunate to pick up a Ribbons. Loving it but scratching my head on one thing.
After I record a loop with some tape effects applied, I want the option to play my “dry” signal over the recorded loop.
I haven’t been able to figure out how to do this or how to have loops be separate from my signal. Is this possible? I’d hope so.
Yup! It’s easy. Just set the pedal to “buffered bypass with trails” and then bypass the pedal after recording your loops.
You’ll still hear the loops playing back but your dry signal will be unaffected and you can play over your loops :slightly_smiling_face:
You can use the MIX control as a master volume for all the loops.
Thank you. I do appreciate the response but it isn’t exactly what I’m looking to accomplish.
I’m basically asking if there is a way to treat the looper and the tape effects as separate pedals (effectively).
I know I’m not articulating this super well. I’ll describe literally what I’m trying to do:
  • Record a loop that has various tape effects applied to it
  • “print” or lock that loop, then be able to play over it while being able to use Ribbon’s tape effects to change my input but without changing the loop.
Right now, when I attempt this, any parameter changes I make to impact my signal (the IN) ALSO changes the loop that’s recorded (unless I’m loosing my mind!).
Does this make sense?
Basically - I want to still be able to use the tape effects while using the looper.
I think what you’re asking for is…
This is on our list to investigate for the next Ribbons firmware update.
Yes, that is it (stated much clearer than I put it!). Thank you. This would be huge.
Any estimate as to when the update might come? I understand you probably cannot say too much here - but is there a ballpark? (I.e. this year still, early next, etc?)
Thank you
We’d definitely like to get another update out before the end of the year but we’ll have to see how things shake out with the production / manufacturing stuff we’ve got lined up this fall.
Maybe before the end of the year? Uh, that would be amazing <3
