Definitely. This is on my list of to-do’s.
You know all my secrets! This is possible but the short answer is that it probably won’t be a feature of Ribbons. There is a reverb/resonator sibling pedal in the works that does way more with the reverb (including infinite verb).
Like the static/clicks and pops to be more extreme? Or another parameter?
I wrote the Tape Stop code quite awhile ago and it was implemented in a way that doesn’t allow attack and release times to be changed mid-stop or start. I have some new tricks up my sleeves and plan to re-write it so that it can do exactly what you’re mentioning here! This is a bigger lift but it will get done eventually.
Originally I set things up so the parameters could be modified in a “relative” way but there was something about it that I really didn’t like (fml - I can’t remember what it was and am not finding any notes on it). I’ll add this to my backlog of things to revisit.
With buffered bypass, Ribbons will continue to play reverb trails and magnetic dance when the effect is bypassed but new incoming audio will be dry / not affected.
